Engine number
13 years 6 months ago #14516 by Proton_Ice
Replied by Proton_Ice on topic Engine number
Hi Wallip,
Can you tell me if the VIN tell if the car come with auto ou manual transmission ?
Thanks,
13 years 6 months ago #14524 by wallyp
Replied by wallyp on topic Engine number
I don't believe that there is a code in the VIN to tell you that, but Porsche has the original manufacturing data by VIN. There used to be a Russian site that had those records - no idea if they are still on the web.
Here is a site that gives the info shown by the VIN:
stuttcars.com/technical/vin-decoder/
There should be a build sticker under the carpet in the hatch area that gives the option codes for the car. The option code for automatic transmission is 249.
Earlier versions of PET (the Porsche parts list) had the car options by VIN, but that has apparently gone away.
13 years 6 months ago #14560 by Kiln_Red
Replied by Kiln_Red on topic Engine number
Proton,
Both engine harnesses are compatible with either a manual or auto transmission. You can determine which harness you need from your engine serial number. The serial number is stamped just below M28.xx ..
One example would be 81H00957. If that were the serial number, then you would need engine harness # 92860700214
Tell me what your engine serial number is. :)
13 years 6 months ago #14575 by otisp1
Replied by otisp1 on topic Engine number
As far as PET goes, it says your VIN has auto trans. Engine M28.42 and trans A28.12. Also LSD.
