door stuck closed
- john a. volak
13 years 10 months ago #13205
by john a. volak
door stuck closed was created by john a. volak
i knowdessed my driver door will not open. this is a new problem. does anyone know how to open a closed door? when i removed the key lock before it became stuck, i saw that the white bracket that connects to the lock was off. now i have to get into the lock to try and put it back on. but with it stuck closed i cannot remove key lock to try to find bracket. please help. thanks, john
13 years 10 months ago #13207
by the flying scotsman
Replied by the flying scotsman on topic door stuck closed
you should be able to open from the inside from the passenger side.
The door handle failure is quite typical and theres many write ups on how to repair
Attached files [img]media/attachments/13564=1598-door handle.JPG[/img]
