1980 5 speed electrical issue
14 years 3 months ago #9841 by 928mac
Read this to help diag batter drain.
the link is in our tips section
forums.928oc.org/vbulletin/showthread.php?t=864
and another good step by step on cleaning 928 GROUNDS with pictures
forums.pelicanparts.com/porsche-928-tech...eaning-16v-euro.html
plus one more
forums.rennlist.com/rennforums/2220328-post33.html
14 years 3 months ago #9873 by GlennS
Stan, Brad,
Thanks for the advice. Brad lots of helpful instructions and pictures; it will take a while but I will work through it.
Glenn
Glenn Simpson
14 years 3 months ago #9876 by 928mac
Let us know how its going as you complete each step.
You should document it in your car profile page.
14 years 3 months ago #9893 by GlennS
OK. Will do.
Glenn Simpson
14 years 3 months ago #10202 by wallyp
First thing to check is the alternator belt - it should be really tight and unworn. If the V-belt on the older cars touches the bottom of the pulley groove, it is worn out.
14 years 3 months ago #10232 by Kiln_Red
These cluster gauges simply aren't usually too trustworthy. As others have said, check your voltage with a multimeter when the gauge seems inaccurate. You'll likely find that it is charging correctly though the gauge is indicating a low charge.
