warning light is coming on alot now
14 years 6 months ago #9200 by tedder
When I first got the 1986 S the warning light would come on once in a while. Now its on almost all the time and sometimes blinks on/off when I hit a bump. No other indicators are showing on the dash. What could it be?
14 years 6 months ago #9203 by pcar928fan
Probably one of the indicator lights is burned out and that is the one that is faulting... You need to check that ASAP. When you turn the key to the aux position all the dash lights should be on and your owners manual will tell you what/where each light is. You can see if any are burned out. Also if it the systems thinks your engine oil pressure is low it will blink, it will blink if it thinks your alt voltage is to low and I think the T-belt warning gets it blinking too.
14 years 6 months ago #9208 by 928mac
I think it is in the tips section where you can find the owners manuals. They are at the top when you open one of the forums.
14 years 5 months ago #9299 by tedder
tedder;9425 wrote: When I first got the 1986 S the warning light would come on once in a while. Now its on almost all the time and sometimes blinks on/off when I hit a bump. No other indicators are showing on the dash. What could it be?
I filled up my radiator reservoir with coolent and the light doesn't come on as much. I surmise it may come on occasionally as a low voltage warning - when I am running both air conditioners the quage will bounce around 10 volts.
14 years 5 months ago #9302 by pcar928fan
Yup, it will turn on with Low Voltage and low Oil Pressure!
