Timing belt tensioner question
14 years 4 months ago #8722 by ctepley
83 928 S 110000 miles and I am replacing my water pump and timing belt. Do I replace my belt tensioner or do I rebuild it. If I rebuild it what parts do I need. want to make sure I do it right. thanks
Teps
14 years 4 months ago #8723 by 928mac
Hey Tep, good to here you are tackling your car.
Are you going to use dwaynes step by step?
to answer your question.
Most, or at least the fad is to replace the stock tensioner with a PK tensioner.
here is a good read
forums.rennlist.com/rennforums/928-forum...?highlight=tensioner
I rebuilt mine and replaced the belt and then 1 year later I had to replace the belt again due to oil contamination so I installed a PKtentioner.
It is your choice
here are my pictures of it on my engine
14 years 4 months ago #8734 by ctepley
thanks for the help. I am going to use the step by step. Another dumb question. I see tensioners with and without air pump. Is this for different years or is this an option for all cars. thanks
14 years 4 months ago #8741 by 928mac
ctepley;8908 wrote: thanks for the help. I am going to use the step by step. Another dumb question. I see tensioners with and without air pump. Is this for different years or is this an option for all cars. thanks
I think it is if you remove the pump.
14 years 4 months ago #8742 by the flying scotsman
The bracket for the tensioner can be ordered with or without the air pump provision given that the air pump is no longer fitted to the 928 and not required for the car to pass emmision testing.
This would be when fitting the Porkensioner. If you decide to stay with the OEM tensioner the air pump can still be deleted if desired and retain the OEM bracket.
The issues with the OEM tensioner are well documented, expensive and despite best efforts do not function as the more modern Porkensioner.......... also the Porkensioner doesnt leak oil :)
14 years 4 months ago #8745 by martinss
malcolm;8916 wrote: ... the air pump is no longer fitted to the 928 and not required for the car to pass emmision testing....
Malcolm: Not to hijack this thread, but when you say the air-pump is not required is that because:
  1. A well tuned car can still meet original standards without it?
  2. In your jurisdiction standards are lower or non-existent for this age of car?
  3. With a newer type of cat the pump is not required?
Thanks
