If you want to build a better limited slip
14 years 10 months ago #7613 by 928mac
For Example if you have a used LSD unit and you want to turn it into a Greg Brown Limited Slip Differential, then this is what you do
Greg gave me his ok to post this.
They, Porsche, "bounced" around quite a bit on what pieces they installed. Lots have two friction discs, but they are touching each other, without an outer lamina between them. The result is the same...there are only two friction surfaces touching outer lamina on each side.
If the friction disc is completely toast. The moly coat is worn down so that the "peaks" are almost all gone and the surface is virtually worn flat. The next step is for that surface to start "smearing" the peaks and valleys together.
If you want to build a "better" limited slip, buy yourself 4 new inner friction discs, instead of just the two....from Porsche...or from someone that bought them from Porsche (do not use aftermarket friction discs....they are not of adequate quality.)
Assemble each side this way, starting from the "inner pressure ring" and working your way towards the outside:
Inner Pressure ring
Inner friction disc
Outer lamina
inner friction disc
Outer lamina
Spring washer
Start with 1.9 or 2.0 outer lamina pieces.
Assemble the entire unit, using a gear oil with the proper friction modifiers that work with this style limited slip. Mobil 1 LS is easy to get and ecconomical (Auto Zone).
Bolt the entire thing together. Install 6 temporary bolts and nuts (with washers on each side of the differential to not damage the surface where the ring gear sits), where the ring gear normally bolts (to make sure the unit is completely squeezed together.
Install a CV stub axle on each side. One stub will have two 10mm bolts (or studs) inserted 180 degrees apart. You will clamp these two bolts into a vise.
For the other stub, you will need to make a little flat plate that bolts across the flange with two 10mm bolts 180 degrees apart. In the center of this plate, weld a 17 or 19 mmm headed nut.
This nut will allow you to turn the limited slip with a torque wrench. measuring the amount of friction the unit has. You can turn it 20-30 times to get the inner friction discs to "settle" in. Now use a torque wrench to turn the unit. I think that the "ideal" friction, for new friction discs is right about 40 ft lbs. You can switch the "outer lamina pieces" to adjust this pressure. They come in 1.9, 2.0, and 2.1mm thicknesses. You should be close, if you assemble the unit like I described. If your pressure is very low, install new "spring" washers on the outside...they get "soft" over time.
If you don't understand, I can take some pictures of the flat plate with the nut all mounted in the vise.
I've got a couple of these things to "set-up", next week.
If you have any trouble finding any of the pieces, I stock all the pieces, multiple times over....including new prssure rings, inner friction discs, outer lamina (in all three sizes), spring washers, and thrust washers.
__________________
gb
Greg Brown
14 years 10 months ago #7616 by pcar928fan
NICE! GB is THE MAN!
14 years 9 months ago #8309 by turbohugh
Im still trying to visualize this.
Will this work in the 'open' diff also?
Thanks in advance,
14 years 9 months ago #8310 by 928mac
turbohugh;8481 wrote: Im still trying to visualize this.
Thanks in advance,
in a word (no) ;)
14 years 7 months ago #8602 by Normy1
928mac;7783 wrote: For Example if you have a used LSD unit and you want to turn it into a Greg Brown Limited Slip Differential, then this is what you do
Inner Pressure ring
Inner friction disc
Outer lamina
inner friction disc
Outer lamina
Spring washer
__________________
gb
Greg Brown
I have a problem with both tires going up in smoke if I get on it in first gear. 5 mph rolling start in first, nail it, roll about 75 feet...and then it gets into the power band and both tires loose traction. S2 5 speed, rear tires are 274/40-17 Falken RT-615's.
Any suggestions? If I could "hook up" the car would be way easier to drive!
N
14 years 7 months ago #8604 by 928mac
Normy;8776 wrote: I have a problem with both tires going up in smoke if I get on it in first gear. 5 mph rolling start in first, nail it, roll about 75 feet...and then it gets into the power band and both tires loose traction. S2 5 speed, rear tires are 274/40-17 Falken RT-615's.
N
Hmmm never had any one complain that they had to much power before.
To answer your question
To get traction you need soft compound tires and as wide as will fit.
Then you need weight transfer.
1 way is to go to a shock that will allow the front to pop up when you nail it, but that will also change the way the car handles and I have no idea what is available for a 928
Ask on Rennlist if you want but I don't think anyone there will help, then again, never know till you ask.
You are looking for a 60/40, or 70/30, or 80/20 shock if you get the drift ;)
