Porsche 928 factory alarm
14 years 10 months ago #7573
by Glenn
Porsche 928 factory alarm was created by Glenn
My 84 928s came with a factory installed alarm. What are the buttons marked "EXT 1" and " * " used for on the alarm key FOB? Also there is a small button on the side of the FOB, what is it for?
14 years 10 months ago #7578
by the flying scotsman
Replied by the flying scotsman on topic Porsche 928 factory alarm
I dont believe there was a factory alarm that cam e with a key fob although the Porsche alarm is set by locking /unlocking the car and the dash button.
Theres a complete section in the owners manual.....let us know if you dont have it.
14 years 10 months ago #7581
Replied by pcar928fan on topic Porsche 928 factory alarm
Not for 928's there wasn't.
14 years 10 months ago #7587
by Glenn
I bought the car used and it already had an alarm system installed. It is integrated into the system. It not only locks/unlocks the doors, but aromatically arms itself after one minute of exiting the vehicle. That is why I assumed it was a factory installation. By the way, what dash button? Thanks for your input.
Replied by Glenn on topic Porsche 928 factory alarm
malcolm;7748 wrote: I dont believe there was a factory alarm that cam e with a key fob although the Porsche alarm is set by locking /unlocking the car and the dash button.
14 years 10 months ago #7596
by 19psi
Replied by 19psi on topic Porsche 928 factory alarm
'84 may be different than my '82 but my system simply arms when any door is locked with the black key. If a door is open a horn sounds (not the trumpets) and the car cannot be started.
The red aux. key is used when you don't want to use the alarm system. Good for valet or leaving with a mechanic as it also won't open your glove compartment.
The system is invisible on my '82. I have no dash switches or buttons.
14 years 10 months ago #7601
For later cars with the power lock button it is on the dash below the climate control head to the right of the "!" button. Early cars do not have that button.
That button DOES NOT turn on the alarm. To engage the factory alarm (if it is installed) you lock the car from the outside using the longer black headed key. As noted above the red key will not engage the alarm (if installed) and will not open a locked glove box. Good for valet and in fact I think is called the valet key actually.
After market alarms are notoriously BIG TROUBLE in 928's!
