Good morning :) Aug 16th
15 years 3 months ago #5913
Replied by srshaw3 on topic Good morning :) Aug 16th
Out of more than idle curiosity;
Do you mind stating how much the conversion cost you for all the parts?
Would you be able to estimate the time required for the average backyard mechanic?
Good to hear it is working out for you
15 years 3 months ago #5915
Replied by 928mac on topic Good morning :) Aug 16th
I do not mind at all Stan
I bought the TEC-4 GT off of Carl
www.928motorsports.com/parts/tec_gt_engine_management.php
At the link above it states this
I didnt ask as it will be the last purchase of thousands left to spend
His price for my car was $3520 plus it was when our dollar was low so it cost me $4000
The fuel rails were$260
www.928motorsports.com/parts/aluminum_fuel_rail_kit.php
He removed from stock the steel braided lines which I think were around the same so I spent around $500 plus for lines and chrome rails
I also had to buy bulk line and fittings to complete the kit
Malcom sent me his used FPR for shipping but I padded it.
Now with the TEC kit install I did the upper intake refresh, head gaskets, used silicon vacuum lines.
I bought a full engine gasket kit from Roger
bought performence head gaskets from Carl $200 which Ive desided not to use(still have them)
bought the PK tentioner
bought the super clamp
I'm forgetting lots
928ms upper control arms, drilled rotors from roger, electronic window switches, wheels off Malcolm
We think I spent around $10,000 or more. + $145 amsoil, $$ coolent, $$ paint
Ok the second part of the question.
Can a back yard mechanic install this kit.
I would say not if you have all the trouble that I had, with some connectors missing, diode missing, wrong Map sensor making my first time learning the program and trying to tune accordingly a nightmare. Some glitches in the manual including incorrect connections to the LH/EZK relay,
but
Now that I know what I know it would be much easier.
If you can do your own wiring, to build your own harness, then we/I/and others can talk someone through the install.
I do like the kit but I can not compair it to any others.
I think Lizard on rennlist has done a few installs of different kits.
Did I leave anything out?
- The entire stock ignition system (yes)
- The entire stock fuel injector system (This is not true, nothing supplied)
- The entire fuel injector wiring harness (you get the ECM and 32 wires/connector)
- The distributor caps, ignition coils, and spark plug wires (removed)
- The stock LMB (injection) computer (delete)
- The stock EZK (ignition) computer. (delete)
- The stock MAF (Mass Air Flow) Sensor (delete)
I'm forgetting lots
but
15 years 3 months ago #5924
I was only thinking of the electromotive and related parts. Just in case I decide I need to get away from the stock electrics
15 years 3 months ago #5926
I am sure you could handle it but it is a lot of work.
It is best to tune it on a dyno but I don't have that option so its done on the street and while I drive it.
It is a much more modern system that compliments our engine.
Shop around, send electromotive an e-mail for the closest dealer
www.distributorless.com/
Stan.Shaw@Excell.Net;6070 wrote: I was only thinking of the electromotive and related parts. Just in case I decide I need to get away from the stock electrics
