Cylinder Head Gasket Time
15 years 10 months ago #2793
Cylinder Head Gasket Time was created by 928mac
Can I remove the cams and cylinder head and reinstall without the special tools?
15 years 10 months ago #2794
by the flying scotsman
Replied by the flying scotsman on topic Cylinder Head Gasket Time
yes...........with the crank at 45 degrees the cams will spin without valves hitting pistons so can be set at a position where they have the least amount of spring pressure. Just back off the cam holder bolts evenly and only a few turns at a time.........theres a Porsche workshop short movie in Jims CD collection.
15 years 10 months ago #2799
As Malcolm already answered, yes you can. I only wanted to add that I think the videos he mentions can actually be viewed on YouTube.
Replied by Kiln_Red on topic Cylinder Head Gasket Time
malcolm;2892 wrote: yes...........with the crank at 45 degrees the cams will spin without valves hitting pistons so can be set at a position where they have the least amount of spring pressure. Just back off the cam holder bolts evenly and only a few turns at a time.........theres a Porsche workshop short movie in Jims CD collection.
15 years 10 months ago #2805
Go to YouTube and enter "Porsche 928 engine training" in the search menu. I think that will pull up 3 videos. Each is about 10 minutes long if I remember correctly. The car they are using in the videos is an '86, however, they add notes where necessary for the '87+ cars. You should easily understand it. It is quite an interesting set of videos. They specifically show how to remove the cams and the heads, too. You may also learn quite a bit of other miscellaneous information you didn't already know about the 928 engine. I remember saying to myself a couple of times, "Hey, I didn't know that."
