Cylinder Head Gasket Time
15 years 8 months ago #2793 by 928mac
Can I remove the cams and cylinder head and reinstall without the special tools?
15 years 8 months ago #2794 by the flying scotsman
yes...........with the crank at 45 degrees the cams will spin without valves hitting pistons so can be set at a position where they have the least amount of spring pressure. Just back off the cam holder bolts evenly and only a few turns at a time.........theres a Porsche workshop short movie in Jims CD collection.
15 years 8 months ago #2795 by 928mac
Replied by 928mac on topic Cylinder Head Gasket Time
Thanks Malcolm
15 years 8 months ago #2799 by Kiln_Red
Replied by Kiln_Red on topic Cylinder Head Gasket Time
malcolm;2892 wrote: yes...........with the crank at 45 degrees the cams will spin without valves hitting pistons so can be set at a position where they have the least amount of spring pressure. Just back off the cam holder bolts evenly and only a few turns at a time.........theres a Porsche workshop short movie in Jims CD collection.
As Malcolm already answered, yes you can. I only wanted to add that I think the videos he mentions can actually be viewed on YouTube.
15 years 8 months ago #2801 by 928mac
You wouldn't have a link would you Austin
15 years 8 months ago #2805 by Kiln_Red
Go to YouTube and enter "Porsche 928 engine training" in the search menu. I think that will pull up 3 videos. Each is about 10 minutes long if I remember correctly. The car they are using in the videos is an '86, however, they add notes where necessary for the '87+ cars. You should easily understand it. It is quite an interesting set of videos. They specifically show how to remove the cams and the heads, too. You may also learn quite a bit of other miscellaneous information you didn't already know about the 928 engine. I remember saying to myself a couple of times, "Hey, I didn't know that." :)
