928 GT Repair Northern New Jersey
5 years 6 months ago #21857 by Siriam
Hi - Any suggestions for a private Porsche repair ship specializing in 928? I have a 1989 GT that needs some maintenance and water pump.
PS: Best advice on the replacement water pump?
Thanks to all.
5 years 6 months ago #21859 by Rich928
Private message sent with recommendation.
It is recommended to use a waterpump with a plastic impeller. If the bearings begin to fail, the plastic impeller will not damage the block where the metal blades will.
5 years 6 months ago - 5 years 2 weeks ago #21877 by Gary Knox
If Rich didn't recommend this one, there is a guy in Philly who does a lot of mid-Atlantic services. Goes by the name Mrmerlin on Rennlist 928 Forum.
Also, a guy in the Boston area who does essentially all the New England 928's. worf928 is moniker on Rennlist.
There is also a guy named Pete who I think is on Long Island.   Can't remember his last name or Rennlist name, but if you contact 'SteveG' on Rennlist, I'm believe he can provide the info, as I'm pretty sure Pete did service on his '93 GTS which he recently sold.   You can reference me as info source if you want.
Gary
Last edit: 5 years 2 weeks ago by Gary Knox.
5 years 6 months ago #21879 by Rich928
Gary, you're correct. Mr. Merlin was who I recommended. Worf928 and I work together to keep 928s on the road.
1 year 10 months ago #22796 by Zimoludek
Hi, Who did you end up with to do work on your 928. I also have an 89 just mine one an S4 and I’m looking for someone to do a timing belt and water pump while there. I’m also in Northern NJ to be more exact Mahwah NJ. Thanks Adam
1 year 10 months ago #22797 by Rich928
It is some distance from Mahwah, but I know Robert Lucarello of Bob's Motor Works in Atlantic Highlands, NJ owns and works on a lot of 928s.
