Brakes
6 years 10 months ago #21102 by sky22blue
Brakes was created by sky22blue
86 928 After driving about a hour ( with moderate braking ) brakes not releasing at all four wheels all four wheels are hot
6 years 10 months ago #21104 by Trainer
Replied by Trainer on topic Brakes
your brakes are binding. You need a new master cylinder.
6 years 10 months ago #21105 by sky22blue
Replied by sky22blue on topic Brakes
Thanks Trainer It doesn't do it all the time. I drove about 45 miles brakes were OK. Drove about 5 miles applying brake 8 -10 times before it started binding. Car has ABS and my left rear speed sensor is defective it is an early 86 and I can't find a replacement. . Engine bay around master cylinder area was very warm.
6 years 10 months ago #21106 by Trainer
When the washers are getting hard in the master it behaves that way. The problem will be intermittent not constant. Change the master and while you are at it you might as well overhaul the calipers as well. The age of the car suggests this is necessary.
