Euro engine
14 years 4 months ago #9588 by smtcapecod
Replied by smtcapecod on topic Euro engine
pcar928fan;9829 wrote: Steve,
You are quite wrong... EURO '85 engines are 4.7L
Yup, I stand corrected (twice).
Always more to learn, apologies for posting errata this time.
pcar928fan;9829 wrote: The COOLEST thing to do (since the damn engine is going to be apart anyway) is to build it in to a 5.0L EURO Hybrid engine!!! Use a 5.0L bottom end, and fly cut the pistons and use the EURO S top end!
Concur with that, too.
14 years 4 months ago #9589 by pcar928fan
Replied by pcar928fan on topic Euro engine
Steve,
There is always more to learn and I was not trying to be an A$$ about it... If I came across that way I apologize! I am going to just go ahead and SAY IT OUT LOUD RIGHT NOW... I don't know everything! There I admit it! LOL!
I AM however, working on an iPhone app that knows more than me about 928's and it will be out in 2 months if all goes well as we start to see the finish line on this project... It will answer most all your questions about 928's or connect you to a place that does! :D
14 years 4 months ago #9600 by xstepson
Replied by xstepson on topic Euro engine
The beauty of using a 4.7L block is that up until '85, the flex plate migration was SUPPOSEDLY limited by use of a system of circlips and washers. That is one reason you very seldom hear of Thrust Bearing Failure in 928's older than '85. In '85, for some reason, they discontinued the circlip/washers and the TBF became more of a problem. (my '84's have the circlip)
Of course, the downside to using a 4.7L vs a 5.0L block is the lack of low end power, but you should be used to that since you have already been driving a 4.7L.
I have always wondered why the circlip/washer assembly could not be reintoduced to the breed as more torque tubes go bad and are replaced.
Dave, I hope you get your Euro back on the road soon.
Steve, as James has already stated, I too hope I didn't come across as an a$$. Not my intention at all. Just trying to help a brother along.
14 years 4 months ago #9627 by smtcapecod
powerplant posted on pelican:
forums.pelicanparts.com/porsche-928-used...parts-available.html
And thanks all for the clarifications. No offense taken!
I'm of similar mind, if I had it all down pat, I'd be bored and moving on to a different type of car to fawn and get frustrated over!
14 years 4 months ago #9628 by Normy1
Replied by Normy1 on topic Euro engine
stepson;9865 wrote: The beauty of using a 4.7L block is that up until '85, the flex plate migration was SUPPOSEDLY limited by use of a system of circlips and washers. That is one reason you very seldom hear of Thrust Bearing Failure in 928's older than '85. In '85, for some reason, they discontinued the circlip/washers and the TBF became more of a problem. (my '84's have the circlip)
4.7 liters versus 5.0 liters [286 versus 302 in my language; I was born in Detroit] isn't going to make much of a difference in torque. The intake and cams make a far bigger difference.
14 years 4 months ago #9630 by 928mac
Replied by 928mac on topic Euro engine
Dave my advice would be to use a stock engine.
If you want more power you and do a few mods that will help.
removing the Cats, keeping 16 rims on gives you more torque then 17"
