Future owner of a 1984 928S that has been sitting for approx 8 yrs??
8 years 6 months ago #20225 by jcholva
Need advice on steps to get the car to the stage of actually cranking over the engine.will have car towed to my house. I know it will be a long process but the opportunity is just to good to pass up
8 years 6 months ago #20229 by silver928
congrtas on getting the 928...first thing would be to check and drain the gas tank as any gas in there is bad. next replace the fuel pump and fuel filter (under cover in back under fuel tank). Also have to make sure all fuel lines are clear/clean.
all fluids need to be changed prior to trying to start, especially engine oil.
Some people pull the plugs and squirt Marvel Mystery oil in each cylinder and try to hand crank the motor to see if it turns, if it does, you can get a new battery, with new fuel, oil all set, and give it a crank. you can also check if power is getting from the battery to the front by checking voltage at the jump post front passenger side. if it isnt getting min 12V you will need to get to all ground points and clean the ground points as this will help with all kinds of fixes for electrical issues in the car.
Also you can google "starting a car that has sat for years" and get an idea what others have seen on trying to start a car that has sat for a period of time.
Bob
928 OC - Charter Member
8 years 6 months ago #20231 by jcholva
Bob , thank you so much for the welcome and advice. I definitely don’t want to go into this thing blind so I will probably become a member shortly. I know people will not believe me but I was given this car! and I’m thinking that it’s been sitting , it can sit a little longer , do it right and not break really expensive part. Never in my dreams did I think I would own a Porsche! Now if I could find a barn find 911!!! have a good day!
8 years 6 months ago #20232 by silver928
Where are you located, there are many very knowledgeable 928 guys around the country that can help or guide you along the "journey".
8 years 6 months ago #20233 by jcholva
Clarksville,tn approx 50 miles from Nashville tn . That would be great! Also where in the vin is the production no. I was a little confused
8 years 6 months ago #20234 by silver928
1984 vin details:
1984 928 S VIN Range - WP0JB092_ES86 0001 - 3067 vin build numbers 0001 - 3067
Base MSRP up to: $44,000
L-Jetronic fuel injection system with hot wire air-flow sensor
usually cut over to beginning builds is sept/oct of prior year (1983)
You can check the Registry to see if the car has been entered into it here on the site.
Let me see if I can get a few names in Tenn who can help out.
Bob
