Timing belt
15 years 1 month ago #5430 by denhamfly
Timing belt was created by denhamfly
I started working on my timing belt yesterday, I was following Dwayne’s excellent procedure, the only problem is that Dwayne’s car is an 87 while mine is an 85 so far the only difference I have found is the marks on the cam gear, the 87 has a indention on it and mine does not. I think mine is marked on the inside of the gear with a pill shaped make. Can anyone confirm this?
15 years 1 month ago #5431 by srshaw3
Replied by srshaw3 on topic Timing belt
Sounds right, can you get a photo to post?
15 years 1 month ago #5432 by srshaw3
Here is a document that Wally P. created, perhaps this is for your year?:
www.928oc.org/pdf/T-Belt-1.pdf
15 years 1 month ago #5433 by denhamfly
Replied by denhamfly on topic Timing belt
Stan would it be alright to e-mail you the picture, I can't figure out how to post it.
15 years 1 month ago #5434 by srshaw3
denhamfly;5573 wrote: Stan would it be alright to e-mail you the picture, I can't figure out how to post it.
Sure, you can send it to This email address is being protected from spambots. You need JavaScript enabled to view it.
15 years 1 month ago #5437 by Landseer
Replied by Landseer on topic Timing belt
denhamfly;5570 wrote: I started working on my timing belt yesterday, I was following Dwayne’s excellent procedure, the only problem is that Dwayne’s car is an 87 while mine is an 85 so far the only difference I have found is the marks on the cam gear, the 87 has a indention on it and mine does not. I think mine is marked on the inside of the gear with a pill shaped make. Can anyone confirm this?
Hi. I have familiarity with 85 and 86 cars and might be able to help you.
USA 32V car, right?
The 85 cam gears should indeed have tiny indentations that face the engine.
Looks almost like a cut, the width of a saw kerf. They align with marks on the rear backing covers when engine is positioned at O/T mark (top dead center, cylinder 1).
If engine is positioned at 45 deg BTDC, which is the desired "safe/recoverable" position when removing and replacing the belt, then the little marks are not visible IIRC!
Will see if I can find pictures to help you, or threads where I've previously posted them.
It would be most helpful for you to post pictures of each gear, as well as the harmonic balancer while at TDC to give us a baseline. Am assuming the belt is still on the car.
If not, post pictures of that stuff as it now is postioned.
