Air Intakes Tubes
8 years 4 months ago #20272 by mrgrinch2000
Has anyone found a replacement for the OEM plastic air intake tubes?.
Looking at replacing both of mine.
With the cost exceeding $500 for both I thought I would check to see if anyone had found a cheaper yet better alternative?.
Thanks for the read.
Mr Grinch
8 years 4 months ago #20286 by mrgrinch2000
Replied by mrgrinch2000 on topic Air Intakes Tubes
110 views....and no input or advice...not even an atta boy.
Thanks for the help.
Everyone can stand down......I have found a solution.
Mrgrinch
8 years 3 months ago #20325 by Randolator
Replied by Randolator on topic Air Intakes Tubes
What I've done is wrapped my intake tubes in aluminum-coated bubble wrap and metal tape. It seals them up and insulates them from the high engine temperatures and makes the running temperature of the engine drop significantly. Sounds kludgy but it really works!!
8 years 2 months ago - 8 years 2 months ago #20362 by martinss
Replied by martinss on topic Air Intakes Tubes
I think most people endeavour to keep stock, which is likely why you did not get a reply. On my '88 I found that standard aftermarket air tubes and junctions can be adapted:
I totally would not go with Red if I did it again - black is readily available. The price is a tiny fraction of OE.
Last edit: 8 years 2 months ago by martinss.
7 years 11 months ago #20583 by Fronkenstein
Replied by Fronkenstein on topic Air Intakes Tubes
Aluminum bendable dryer vent tubing :)
7 years 11 months ago #20590 by Rich928
Replied by Rich928 on topic Air Intakes Tubes
Mercedes Benz hose part number
117-094-03-82 tubes will fit. You'll need two per side (total of four).
The following user(s) said Thank You: jWs, hey_allen
