1979 928s ROW help please
10 years 1 month ago - 10 years 1 month ago #19307 by Tim S
Got the motor out for a rebuild since it had a head gasket leak. I am having trouble finding a shop manual or at least torque specs. Can any one help? Thanks all
Last edit: 10 years 1 month ago by Tim S. Reason: Adding photos
10 years 1 month ago #19312 by Kiln_Red
Replied by Kiln_Red on topic 1979 928s ROW help please
What stage of disassembly are you in? I highly recommend contacting Roger Tyson at 928srus for a copy of the Morehouse CD set. There is a wealth of info in there including, but not limited to, the factory workshop manual.
The following user(s) said Thank You: Tim S
10 years 1 month ago #19316 by he_mech_usmc
I will see if I have my copy I can send you when I get back to my computer. I also have a 79 ROW that I have been restoring for a while. I have compiled quite a bit for the 78-79 cars. The torque specs should be the same from US to ROW, but there is a difference for some of the other things since ROW cars don't have a lot of the emission stuff a US car does.
10 years 1 month ago #19317 by Tim S
Replied by Tim S on topic 1979 928s ROW help please
I was able to find some info I am starting re assembly thanks for the info i will check it out
10 years 1 month ago #19318 by Tim S
I appreciate it thanks. The only emissions item on the motor is the smog pump and I am not going to put that back on.
10 years 1 month ago #19319 by Tim S
Thanks for the help almost all back together now
