catalytic converter removalel
13 years 9 months ago #12049 by patanna2
Thinking about removing catalytic converter and replacing it with a Y and straight pipe and leaving the muffler as is. I'm hoping to improve sound. Any thoughts on this. It's an 81 so no omission is required.
Pat
13 years 9 months ago #12050 by Kiln_Red
It would be just slightly louder. I hollowed a cat once on my '84 auto. Marginal is the word that I would use to describe both the change in sound and performance.
13 years 9 months ago #12060 by 928mac
Opening up and exhaust will not help if the exhaust is all ready big enough to handle everything that the intake can deliver.
If the engine has a significant amount of back pressure, then opening up the exhaust will allow more intake air and fuel to pumped through the engine. (remember the engine is just a piston pump)
This also has a lot to do with intake design and efficiency.
When I removed my catalytic convertors and bolted on the same style pipe, I believe the engine breathed better and that there was a bit more seat of the pants umpf
I have no numbers to prove this, but some others have posted their dyno numbers on the net.
The sound did get throatier for me.
I later (just this year) removed my muffler and installed the same open pipe set-up which is called a RMB (Rear Muffler Bypass) but its really just sticking a pipe in-place of the muffler.
I got a lot loader (when floored) and just a bit when cruising.
Some people complain of a loud drone (head ache type) with the RMB.
I will note here that.
When I engineered the H pipe to replace my cats,
I moved the Y where they join, further back to expose the flywheel housing.
I do not need to remove my exhaust to remove my flywheel cover any more.
You can see this in the picture below.
13 years 9 months ago #12108 by mm928
Replied by mm928 on topic catalytic converter removalel
My experience is that earlier cars (through 83 at least) seem to benefit a great deal from exhaust upgrades. However, also check your manifolds. The stock ones on my 83 were horrible iron straws.....so I purchased a used pair of 85/86 and blasted and painted them. I then added the 3-in y-pipe and a new SS hi-flow Cat from Roger at 928sRus. Big difference in breathability and quicker reaction time. I would say the performance must be better as well but I have no numbers. It will rumble like a 32v car.....and this is with keeping the stock pumpkin muffler and rear pipe section after the Cat.
SO I would say definitely consider it. Just check and see if you model year exhaust manifolds are considered pretty good or not and if another model years might fit. I think it is probably a decent bang-for-the-buck upgrade. The last section stock section is likely 2.5 in, I bought a 3in upgrade but did not use a reducer, there is fairly little overhang where they match up. You could do it either way I think. I think also that my write up on it is elsewhere on the site somewhere. Just do a search.
Good Luck!
13 years 9 months ago #12111 by Kiln_Red
I agree with Michael. If you are considering a complete replacement of the exhaust, including the manifolds, you could see more significant gains. A lot of people have updated the manifolds to MY85/86 style and reported a boost in performance.
13 years 9 months ago #12112 by patanna2
Thanks Guy's The response was great , but I'm not surprised. There sure is a vast amount of wisdom within an arms reach when there's a 928 owner's club you can turn to in a time of need..
Sincerely
Pat
