Bought another 928
14 years 1 week ago #10056 by Kiln_Red
Bought another 928 was created by Kiln_Red
Picked one up for a DD maybe 5-6 weeks ago now. Been a good car. It's an '84, black on black, 5 speed car. Minor deferred maintenance things to sort. Tonight I'm going to pull the cluster to see what's with the intermittent Speedo. Probably the flexible printed circuit as usual and/or rivets. Anyone else ever had issues with the Speedo here before? Personally, I never have with other 928a but I know many out there have documented the issues before.
14 years 1 week ago #10058 by 928mac
Replied by 928mac on topic Bought another 928
I hope it all works out Austin.
Have you posted a picture of it yet?
14 years 1 week ago #10063 by Kiln_Red
Replied by Kiln_Red on topic Bought another 928
No pictures yet, but I'll post some soon under my member car profile. I got the cluster out last night. I couldn't visually tell that anything was wrong with the flexible PCB. Since I was already questioning the connection the 3 small rivets were making, I proceeded to solder as Dwayne documented. Set the cluster back without the pod cover just to see if the soldering had fixed the speedo. No change. I guess for now I will just swap clusters with my other '84 until I can get a new flexible PCB. I doubt cleaning my contacts will make any difference. I'm sure there is just a small break in the circuit somewhere that I cannot find.
14 years 5 days ago #10073 by xstepson
Replied by xstepson on topic Bought another 928
Austin,
Did you check the connections in the spare tire well? The speedo sensor wires come up through there and there is a connection that has a possibility of corrosion.
14 years 5 days ago #10079 by pcar928fan
Replied by pcar928fan on topic Bought another 928
stepson;10378 wrote: Austin,
I need to check this on my '95... Thanks for that info John, I forgot that is where the wires come through!
14 years 5 days ago #10084 by Kiln_Red
Yes. I checked that plug first I think. I didn't visually see anything questionable about the connection. Later in my search, I measured voltage across plug H1 and H2. A helper then rolled it forward so that I could see the circuit pulsate.
